Good afternoon. I’m looking for a picture or description of where you’ve placed the fresh air door cable clips on the firewall. The FSM seems to show one up high in the outer corner and another pretty close to where the cable enters the vent area. I’m using my original cables, and on the passenger cable, there are actually two non-tarnished areas where the clips fit, but that will only work if I use two lower fasteners that hold the firewall cover in place. My cables are not long enough to reach up into the higher location. I know this isn’t a major show stopper, but I’d like to get it as close to correct as I can.
Thank you,
Larry
