| | | Forums66 Topics128,160 Posts1,057,054 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Good afternoon. I’m looking for a picture or description of where you’ve placed the fresh air door cable clips on the firewall. The FSM seems to show one up high in the outer corner and another pretty close to where the cable enters the vent area. I’m using my original cables, and on the passenger cable, there are actually two non-tarnished areas where the clips fit, but that will only work if I use two lower fasteners that hold the firewall cover in place. My cables are not long enough to reach up into the higher location. I know this isn’t a major show stopper, but I’d like to get it as close to correct as I can. Thank you, Larry | | |
