4 members (greenie-reddy, Jon G, cmayna, dt235sd), 26 guests, and 4 robots.
Topics128,021
Posts1,055,372
Members48,420
#1501437 05/19/2023 11:39 PM
It was suggested that I post here regarding what transmission, drive shaft & rear end would be needed or modifications if I replace the worn out 216 in my truck with a 235. I have a friend who has a 235 w/ bell housing and clutch. My truck has a worn out 3 speed, 411 rear end & u-joint. What are your recommendations for the upgrade?
ronsway #1501487 05/20/2023 4:21 PM
Does the current setup have an open driveline or a torque tube? What is an "AK" BTW? I'd suggest a SM-420 4 speed and whatever rear axle matches your front wheel bolt pattern, if possible. Are you planning any kind of modern upgrade to the front suspension and/or brakes along the way? It would be a really good idea to have the wheel bolt pattern match, front to rear.
ronsway #1501491 05/20/2023 4:41 PM
AK is the predecessor to the AD truck in GM nomenclature.
1950 Chevrolet 3100 (Ol' Roy)
Otto Skorzeny #1501544 05/21/2023 12:45 AM
I believe he is telling us he has a 1941 1/2 ton truck, Model 'AK'...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
