| | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | It was suggested that I post here regarding what transmission, drive shaft & rear end would be needed or modifications if I replace the worn out 216 in my truck with a 235. I have a friend who has a 235 w/ bell housing and clutch. My truck has a worn out 3 speed, 411 rear end & u-joint. What are your recommendations for the upgrade? | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Does the current setup have an open driveline or a torque tube? What is an "AK" BTW? I'd suggest a SM-420 4 speed and whatever rear axle matches your front wheel bolt pattern, if possible. Are you planning any kind of modern upgrade to the front suspension and/or brakes along the way? It would be a really good idea to have the wheel bolt pattern match, front to rear. Jerry
| | | | | Joined: Oct 2021 Posts: 6,688 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,688 | AK is the predecessor to the AD truck in GM nomenclature.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | AK is the predecessor to the AD truck in GM nomenclature. I believe he is telling us he has a 1941 1/2 ton truck, Model 'AK'... Mike B  | | |
