2 members (78buckshot, NJC),
98
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 92 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 92 | Here are a few more pictures of the old girl in the rehabilitaion process. Now don't laugh at the dents, rust holes, brush marks and ripples. But I don't blame ya if you do... the work that everybody does on this site is quite amazing. Though I'm capable of doing that type of work myself I simply don't have the time and space right now to accomplish that sort of restoration. The premo body work will have to wait, but I'll be able to work it one section at a time and still be able to use the truck. Mechanically she's pretty tight. Check out the Fentons and Dual Carbs. She should be on the road by the end of the week, if the windshield and rubber arrives. So I'll have a few more pictures and maybe a more complete list of the works that been done. Until then, thanks for all the responses and inspiration. Pauly. http://community.webshots.com/user/PaulyBuiltInc
1948 Chevy 6400 1964 Chevy 1/2 Ton
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Nice pics. Did you put a new rubber floor mat in yours? If so where did you get it and did you have to do much fooling around to get it to fit correctly? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | The '48 is looking great. You have came a long ways from the first pic. | | | | | Joined: Dec 2006 Posts: 92 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 92 | Super55, the floor mat is new and I got from The Filling Station in Lebanon, OR 1-541-258-2114. It didn't take much to get it to fit...the mat had marks for the gear shift, etc. so I had to cut those out. If you had the old one it might be easier to use that as a pattern. Other than that it fits pretty nice.
| | | | | Joined: Nov 2004 Posts: 2,420 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,420 | Looks great, what kind of tires did you get, are those 20"?
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Dec 2006 Posts: 92 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 92 | Hi John. The tires pictured (front axle) are "CEAT" 8.25 x 20. My dad was helping a local farmer clean out his barn and they found 4 matching 8.25 x 20 Goodyears (about 85%) that they gave me for the rears. Sweet find.
| | | | | Joined: Jul 2006 Posts: 32 Junior Member | | Junior Member Joined: Jul 2006 Posts: 32 | Pauley, I have not seen that type of dual carbs before. Do you have anymore info on them? Anyone else seen this setup before? | | | | | Joined: Dec 2006 Posts: 92 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 92 | Hi obsa. The dual carb is a home built setup I put together. I originally wanted to put on a 2 x 1 intake, but it looked like the back carb would be in the way of the fender support rod. The little "adapter box" bolts onto the stock intake manifold and then the two carbs on top of that. I also built another adapter to mount two oil bath air cleaners on top of that. Things got a little tall, the hood won't close, so I'm on the search for two smaller matching air cleaners. The linkage that runs the main carb is close to stock, just longer. The second carb is pushed opened by the cam type linkage when the main carb is opened. This linkage didn't end up as progressive as I wanted, but the're both WOT at the same time.
| | | | | Joined: Dec 2006 Posts: 8 Junior Member | | Junior Member Joined: Dec 2006 Posts: 8 | Looks good sems like you have been very buisy, glad someone has saved the old lady. Safe Cruisin Chris | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Be sure and let us know how that dual carb setup works out for you. | | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | Looking good Pauly. Keep up the good work. | | |
