7 members (Joe H , Charles in CA , WICruiser , dt235sd , Donf , JoergK. , 1 invisible),
101
robot. Key: Admin ,
Global Mod ,
Mod
Topics128,259
Posts1,058,301
Members48,485
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Hello what do you use to fasten the throttle linkage to the block? The original pin is missing? Thanks.
1953 with a 216
The pivot pin that goes into the block is missing? I’ve never studied, but I assume there’s a threaded hole where it goes? If, so, I’d think some sort of shoulder bolt would work fine.
1951 3100
1951 3100
AD Addict & Tinkerer
Here is what the the original for the 216 chevy looks like. Post a want ad in the “Truck Parts Wanted” forum, and I’m sure you get a response from a fellow bolter.
Phil
Moderator, The Engine Shop, Interiors and Project Journals 1952 Chevrolet 3100 , Three on the Tree, 4:11 torque tube
Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
1953 with a 216
