1 members (RLB), 215 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#1501269 05/18/2023 4:38 PM
Hello what do you use to fasten the throttle linkage to the block? The original pin is missing? Thanks.
1953 with a 216
The pivot pin that goes into the block is missing? I’ve never studied, but I assume there’s a threaded hole where it goes?
If, so, I’d think some sort of shoulder bolt would work fine.
1951 3100
Or you could buy the right thing:
https://oldchevytrucks.com/mee296.html
1951 3100
AD Addict & Tinkerer
Here is what the the original for the 216 chevy looks like.
Post a want ad in the “Truck Parts Wanted” forum, and I’m sure you get a response from a fellow bolter.
Phil
Project Journals
Stovebolt Gallery Forum
1953 with a 216
