| | | Forums66 Topics128,052 Posts1,055,774 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | I'm losing coolant from the radiator but I can't tell from exactly where. It doesn't appear to be from the hoses but toward the bottom of the radiator. I guess doing a pressure test is the next step but I don't know how to do that and don't have the equipment. I looked in the tech tips for some info but couldn't find anything. My radiator is a Champion aluminum that's about 7 years old. What's your advice? Thanks!
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Jan 2022 Posts: 2,446 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,446 | Most decent FLAPS has a loaner cooling system pressure tester. I know my O'Reilly's and Auto Zone do.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Oct 2021 Posts: 6,762 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,762 | If you know the leak is from the radiator, there's no reason to waste time testing it for a leak.
Take it to a radiator repair shop. Here, the local place charges $65 to clean out the radiator and find and repair the leak.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If one cannot tell where a leak is, it could also be internal to the engine. Park over a clean floor to locate. Could be head gasket, water pump, freeze plug, cracked block!
Ed
| | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | All good points, thanks. I see it coming from near the bottom of the radiator. Off to the radiator shop.
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Check that the lower radiator hose is properly installed and not cocked and leaking fluid back onto the radiator. Mike B  | | | | | Joined: Oct 2021 Posts: 6,762 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,762 | Be sure the radiator shop knows that this radiator is from a zero pressure system. You don't want him pumping it up to 15 pounds to find a leak. My truck has a 4 lb cap.
