0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#1501199 05/18/2023 1:24 AM
I'm losing coolant from the radiator but I can't tell from exactly where. It doesn't appear to be from the hoses but toward the bottom of the radiator. I guess doing a pressure test is the next step but I don't know how to do that and don't have the equipment. I looked in the tech tips for some info but couldn't find anything. My radiator is a Champion aluminum that's about 7 years old. What's your advice? Thanks!
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
B Online: Content
Most decent FLAPS has a loaner cooling system pressure tester. I know my O'Reilly's and Auto Zone do.
If you know the leak is from the radiator, there's no reason to waste time testing it for a leak.
Take it to a radiator repair shop. Here, the local place charges $65 to clean out the radiator and find and repair the leak.
1950 Chevrolet 3100 (Ol' Roy)
Crusing in the Passing Lane
If one cannot tell where a leak is, it could also be internal to the engine. Park over a clean floor to locate. Could be head gasket, water pump, freeze plug, cracked block!
Ed
All good points, thanks. I see it coming from near the bottom of the radiator. Off to the radiator shop.
~Denny
1953 Chevy 3100
Check that the lower radiator hose is properly installed and not cocked and leaking fluid back onto the radiator.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Be sure the radiator shop knows that this radiator is from a zero pressure system. You don't want him pumping it up to 15 pounds to find a leak. My truck has a 4 lb cap.
