1 members (Otto Skorzeny), 95 guests, and 1 robot.
Topics128,034
Posts1,055,552
#1501199 05/18/2023 1:24 AM
I'm losing coolant from the radiator but I can't tell from exactly where. It doesn't appear to be from the hoses but toward the bottom of the radiator. I guess doing a pressure test is the next step but I don't know how to do that and don't have the equipment. I looked in the tech tips for some info but couldn't find anything. My radiator is a Champion aluminum that's about 7 years old. What's your advice? Thanks!
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
Most decent FLAPS has a loaner cooling system pressure tester. I know my O'Reilly's and Auto Zone do.
O Online: Content
If you know the leak is from the radiator, there's no reason to waste time testing it for a leak.
Take it to a radiator repair shop. Here, the local place charges $65 to clean out the radiator and find and repair the leak.
1950 Chevrolet 3100 (Ol' Roy)
Crusing in the Passing Lane
If one cannot tell where a leak is, it could also be internal to the engine. Park over a clean floor to locate. Could be head gasket, water pump, freeze plug, cracked block!
Ed
All good points, thanks. I see it coming from near the bottom of the radiator. Off to the radiator shop.
~Denny
1953 Chevy 3100
Check that the lower radiator hose is properly installed and not cocked and leaking fluid back onto the radiator.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
O Online: Content
Be sure the radiator shop knows that this radiator is from a zero pressure system. You don't want him pumping it up to 15 pounds to find a leak. My truck has a 4 lb cap.
