1 members (Hush), 73 guests, and 2 robots.
Topics128,211
Posts1,057,475
Members48,473
in the kick panel. Can I splice into the regular speaker wire like you can electrical wires? I have an additional speaker set that I would like to add. The speakers that I have are underpowered and a shop said it would be a thousand dollars to upgrade. If I turn them too much I get feedback.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
It shouldn't be a problem to connect a set of speakers in parallel with the existing ones except that you would be changing the load impedance. That may or may not be helpful. The joints of course must be insulated so that they don't short out.
By feedback I assume you mean distortion. Distortion or distorted sound can be caused by an over driven output amplifier or an impedance mismatch between the output driver circuit and the speaker.
1951 1 Ton Completed
The shop I took it to said it was underdriven. I thought it was overdriven.
2017 Buick Encore
See more pix
I don't know what those terms are referring to. If the amplifier output stage is properly matched to the speaker load, it will operate correctly up to a certain output properly within the defined maximum distortion parameters. If there is a mismatch, it will not. If a speaker is driven with more power than what it is designed for, damage can occur.
If you parallel the speakers, it will reduce the impedance by half. so if you have two 4 ohm speakers and add two more 4 ohm in parallel it will be 2 ohms presented to the radio amp. It may play forever or may blow up. But it will be louder for that time span.
1960 Chevy C10 gasser- Rabble Rouser
1953 Harley Davidson Panhead chopper
Add them in series and they'll act like 8 ohm speakers.
But half as loud and not efficient.
True, but unless you are running a monster amp of some kind 8 ohms is a lot safer than 2 ohms on a 4 ohm system.
True, but unless you are running a monster amp of some kind 8 ohms is a lot safer than 2 ohms on a 4 ohm system.[/quote]
Agreed.
Moderated by  truckernix
