1 members (wilbur53), 92 guests, and 2 robots.
Topics128,195
Posts1,057,374
Members48,469
#150102 01/11/2007 7:03 AM
Big Bolt Forum Co-moderator
Hello, I have done a search and can't find any info on the shift pattern plate on my truck (1948 2 ton) that is mounted on the dash. The truck used to be a fire truck, and there is some reference to auxiliary pumps on it. Did all of the trucks of this era have a shift pattern plate on them?
1948 Chevy 2-Ton
#150103 01/11/2007 7:59 AM
that would have been added by the fire apparatus mfgr - the truck would have been cab and chassis or cowl and chassis from the factory, no cheat sheet added for shifting
#150104 01/11/2007 11:36 AM
I have two '48 2t.s. Neither one has a shift pattern plate, just the two-speed directions. One truck has the description of the "No-Spin" rear.
#150105 01/11/2007 3:54 PM
Pete,
Do you have a 48 2 ton with a locker in the rear axle?
•1952 Chevrolet 3800 pickup
---All pictures---
#150106 01/15/2007 11:56 AM
Grigg, what's a "locker"? I'll read the plate again, but I just guessed it was some kind of limited slip differential. There's no lock lever to turn it on and off like on tractors.
