I've had a LOT of valve train issues with my 62 235 over the years, Two new sets of hyd. lifters, new rocker shaft assembly and a couple of broken push rods. Recently I've purchased all new push rods and modified them all (per you guys) with a groove in the bottom of them to allow the air and oil to go through the lifters. The motor is Quieter than it ever has been. I had 15 PSI oil pressure at the top of the head before, now I have about 5. Which is fine, still have plenty of oil for the rocker shaft and getting a lot more oil flow through the lifters. Thanks guys
