3 members (Hotrod Lincoln, Otto Skorzeny, MNSmith), 77 guests, and 3 robots.
Topics128,087
Posts1,056,338
Members48,442
How do you get the little brass clips out of the plug? Super basic thing but I'm trying not to wreck it.
I'm sure there's a trick to it?
1961 Chevy C40 Flatbed 261
2 Offline
Usually you can slide something small and flat into the smaller notch visible on the front side in your posted photo
This notch lets you compress a tab that sticks out of the brass part which is holding it in the black plastic
After removing it
You might have to bend the brass tab back up a bit before reinserting because they aren’t exactly great springs
I usually use a very tiny screwdriver for this task
If you aren’t sure of the process try on a junk one first from the wreckers to get a feel for it
-s
Thanks 2manytrucks, that's kind of what I thought but it was kind of hard to see. Now to hunt down a tiny screwdriver 😂
Small jeweler's flathead screwdriver.
Craig
I ended up using a piece of trapping wire flattened on the anvil, worked alright, although a tiny screwdriver like suggested would be better. Thanks guys!
High Plains yer larnin from them "bolters". Seriously get,or make as was said a tool to trip those little brass triggers thru that little slot,once out adjust so it snaps back in. Can then put in a fresh clean one with no corrosion.
I’ve got a small set of feeler gauges that I used on mine with no problems.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
