| | | Forums66 Topics128,287 Posts1,058,544 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I have a 1953 GMC with a 1955 235 engine and the engine rear main seal is leaking. Is there an easy way the replace the engine rear main seal without removing the engine? | | | | | Joined: Jun 2022 Posts: 559 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 559 | Yes. You'll need a Lisle # 27000 "Sneaky Pete" or equivalent. Drain the oil and remove the oil pan. Pull the transmission enough to clear the input shaft from the pilot bearing/crankshaft. Remove the rear bearing cap and loosen the rest of the the main bearing caps so the crank drops just a little. The Lisle kit has a corkscrew to screw into the old rope seal so you can pull it out. There is also a clamp on a wire with a removable T handle. Clamp on to the new rope, push the wire through, add the T handle and pull the new rope through. Set the new seal in its groove best you can with a wood or plastic stick, leaving 1/16-1/8" tag end. Snug up the caps that you loosened and cut the other end of the seal flush. Replace the seal in the bearing cap, leaving another 1/16- 1/8" tag on the other side from the first one. Torque the mains to spec, bolt the pan on with a new gasket, fill with engine oil, shove the tranny back in and go.
Fairly easy one day job with a helper.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | |
