Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (Hotrod Lincoln, Jon G, Wheelie, Otto Skorzeny, ShopRag, Gdads51, klhansen), 109 guests, and 3 robots.
Topics128,287
Posts1,058,544
Members48,491
#1500754 05/14/2023 4:04 PM
I have a 1953 GMC with a 1955 235 engine and the engine rear main seal is leaking. Is there an easy way the replace the engine rear main seal without removing the engine?
Yes. You'll need a Lisle # 27000 "Sneaky Pete" or equivalent.
Drain the oil and remove the oil pan. Pull the transmission enough to clear the input shaft from the pilot bearing/crankshaft. Remove the rear bearing cap and loosen the rest of the the main bearing caps so the crank drops just a little.
The Lisle kit has a corkscrew to screw into the old rope seal so you can pull it out. There is also a clamp on a wire with a removable T handle. Clamp on to the new rope, push the wire through, add the T handle and pull the new rope through. Set the new seal in its groove best you can with a wood or plastic stick, leaving 1/16-1/8" tag end. Snug up the caps that you loosened and cut the other end of the seal flush. Replace the seal in the bearing cap, leaving another 1/16- 1/8" tag on the other side from the first one. Torque the mains to spec, bolt the pan on with a new gasket, fill with engine oil, shove the tranny back in and go.
Fairly easy one day job with a helper.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
