2 members (1955 1 Series, Hotrod Lincoln), 148 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
#149983 01/04/2007 2:26 PM
I've put a photo on the "Alternative Gallery" of a lever mounted on the bottom of the dash of my '48 2t. The directions printed on the face say to move lever to lock brakes...but doesn't say up or down. Air/vacuum brakes???
#149984 01/04/2007 3:33 PM
J M Offline
I can't find the photo in the Alternative Gallery, but from your discription, it sounds like a microlock switch. If this is what it is, it is an aftermarket valve that is installed in the brake line to set and hold the brakes on. Kind of like an emergancy brake. You hold down the brake and move the lever to set the brake, then to release it you step on the brake and move the lever to the off position. We used devices such as this th hold our wrecker in place when recovering a car.
Hope this helps
Jim
