4 members (JoergK., tclederman, Danielbolt, Peggy M), 177 guests, and 2 robots.
Topics128,175
Posts1,057,052
Members48,460
The pilot seems to have passed out!
And here is the problem with making a post on a mobile phone, it can dump all the stuff you took time to write, in seconds! Let’s try this again!
Looking for tips. I’m making an injection fuel rail for the 302 Jimmy. I need to ream the ends for a -6 o-ring boss fitting. That piece is 24” in length. Even if I stick the thing 15” above the vise ion the table. I don’t think I have enough mill head to get that high. I don't think the lathe has enough capacity to mount it offset in the chuck. I have the correct reamer and it seems to like 1400 rpm. I also have the 9/16-18 tap I need.
I’d hate to have to do this work by hand. Thoughts?
Do you have a milling attachment for your lathe? Hold a chucking reamer in a 3 jaw chuck and mount the rail on the carriage. Then use the milling attachment to center the hole on the reamer, and use a slow feed on the carriage to ream the hole. That's how custom rifle barrel makers gun-drill their barrel blanks before rifling them. You can flow water soluble cutting oil into the drilled hole in the rail to keep the reamer lubed. If the shank on the reamer is too short, weld an extension onto it.
Can you clamp the workpiece to the cross-feed of the lathe and put the reamer in the chuck? I know that's kind of backward, and may take some fiddling to get it lined up with the headstock, but might be worth a try. You might have to machine something to get the work at the right height, but lining it up horizontally should be a piece of cake.
Or maybe stick some round stock in the opposite end for a center point and machine a piece that will slide on it that's supported by a steady rest?
[on edit] Sounds like Jerry got there first with nearly the same suggestion.
Moderator
Moderator
2 Offline
Both suggestions are spot on!
Think outside of the box to get the job done.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Thanks all! That's exactly where I was headed, but didn't know such a thing as a lathe milling attachment existed. Now that I do, I know what I need to do!
Thanks again!
If you had a Bridgeport, you could clamp it to a right angle plate off the side of the bed, then swing the head over and line up on it.
1947 3600 Chevy
Former Workshop Owner
Sounds like what’s already been mentioned is your only option with the equipment you have. But, definitely doable.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Here's mine which I modified ("Surprise- - - -Surprise!" Jim Nabors voice) to fit my lathe, and increased the vertical travel on it.
www.ebay.com/itm/373879962167?
Here’s the facts as we know them. That lathe doesn’t belong to me. If I wanted to get a milling attachment for it, it would require justification, approvals, order the thing, wait almost a year, etc. If I bought it myself, when I retire in five years, I would have no lathe but a nice milling attachment. So, outside the box I go. First, I made a dead center to go along with the live center. Hung the fuel rail. Then, with some scrap 3/4” plate and 1” plate, I made a right angle sled. Lined and squared everything in place. Clamped my piece. Worked like a champ. Reamed and tapped one side, re-lined up and squared the other and repeated. I’m happy.
Now, if I can just get the injector company to ship me my injectors! They’re only on the other side of the county. It really shouldn’t take three weeks (and counting!)
NICE JOB!!
Just proves there's more than one way to skin a cat, as the old saying goes.
Last edited by klhansen; 05/05/2023 4:23 AM. Reason: Thanks, Otto. You knew what I meant.
"more than"
1950 Chevrolet 3100 (Ol' Roy)
Looking good! When Don sees that setup, he's going to award you the same title he gave me some time ago- - - -"Cobble-Ologist"! Or like Smokey Yunick used to claim- - - -"It ain't cheatin' unless you get caught!" When I'm drilling and/or reaming one end of a long piece of stock. I loosen the tailstock clamp slightly, wrap a big bungee cord around the carriage and the tailstock, and let the rear center stay in the end of the workpiece as I feed it over the cutting tool in the chuck.. It adds a little stability to the cut.
Moderator
Moderator
2 Offline
Jerry, that’s Cob-Ologist. If it works, it ain’t stupid!
Get-R-Done and out the door!
Don
"The Flag Pole"
1953 1-ton pickup
Thank you all! I needed that little bit of a kick to get back on the path.
AD Addict & Tinkerer
Creative thinking! Great job! That’s the collective at it’s best!
Phil
Project Journals
Stovebolt Gallery Forum
MSNmith The only difference between ameratures and pros is the pros know how to hide their mistakes !! Good Job. What kind of air cleaner will you use ??
2-ton That is right git-r-done get in it get out the door !! Built a 2-ton 4-link with 7/8 rock climber heim joints for my 6400. I was on the way to the woods junkyard some guy passed and gave me a thumbs -up over his cab !! Always makes you feel good. Junkyard was in fine form, always a lot of action there. Last week went to the big city yard hunting a coil cover for 6-cyl HEI ,they didn't disappoint even let me go upstairs to find it 10$ is 20$ from standard ignition new over the counter.
Probably none. I wouldn't want to hide those horns.
24601
24601
Don -- If you are going to quote me, then the complete quote is: "If it's stupid but it works, then it isn't stupid."
Have to admit, it's actually Murphy's 3rd Law of Small Unit Tactical Combat.
wink
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
John, that one goes hand in hand with another adage- - - -"Never interfere with your enemy when he's doing something stupid!"
Moderated by  MNSmith
