6 members (mick53, 2-Ton, stlcardinalsguy, Wally / Montana, Steelonsteel, Uncles51), 75 guests, and 3 robots.
Topics128,139
Posts1,056,462
Members48,441
Is there any trick or helpfully advice to get rubber into the yrack
Andys
Are you going by the instructions in the Service Manual? It says "Brush a rubber lubricant, NO.3692455, in the grooves of the weatherstrip retainers and on the matching portion of the weatherstrip."
I think you could use some liquid dish soap to lube the rubber.
Well, not to encourage laughter, KY Jelly works well and dissipates quickly. That and a dull screwdriver worked very well when I installed new windlace. Also if not already done, inspect the retainers (tracks?) all the way around and make sure its not pinched shut . I cut a small length or the windlace ( roughly 1 - 1/2 " long ) and tested the retainer / track by making sure that test piece would slide all the way around the track freely. It was necessary to tweak the track in a few areas to enable the test pieced to slide freely. Once that was done I then brushed the lubricant into the track ahead of the windlace as I pushed it through the track ( retainer). It takes a bit of patience but its manageable.
Ron - - Dusty53
1954 Chevy 3604
If you are replacing the original windlace, you will need to undue all of the crimps which were put into the channels on the assembly line.
I cut off a 3/4" piece off of the replacement windlace and run it through the entire length of the channels to find the crimps and pry them out with a screwdriver.
