1 members (Samantha),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 25 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 25 | [my truck is a 1952 chevy 3100 wondering what engine i halve serial # f1207j engin block # 3769716 all help great
floye mungle
| | | | | Joined: May 2015 Posts: 11,027 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,027 | 3769716 would be a 1960 235 CI engine
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2011 Posts: 25 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 25 |
floye mungle
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Your Engine Code F1207J breaks down as follows; F = Flint Engine Plant 12 = Month 07 = Day J = 1/2, 3/4 and 1-ton 235 truck engine. Note, the 235 code "J" was used from 1958 thru 1962. Mike B  | | |
