3 members (ShopRag, Gdads51, 66flea), 94 guests, and 2 robots.
Topics128,214
Posts1,057,486
Members48,473
Big Bolt Forum Co-moderator
I was doing more exploring on my 48 2ton. I pulled the carpet that the previous owner put in. It had a fiber backing that just holds water so I am down to bare metal floor now. I can can keep an eye on it anyhow. I did a temp fix on the throttle linkage. The pedal was sticking in the down position. The pivot where the pedal linkage, and the linkage to the carb connect was stuck tight. I could hardly get my hand on it though. I can't believe that linkage is so hard to get to. You almost have to pull the exhaust pipe to get to it. Anyhow, I loosened the stud just enough to let it release. The pivot isn't moving, but the bolt is. While I was snooping around I located the casting number on the engine, not far from the carb. It was 3836848 and had GM 6. As far as I can decifer on a number search, is that engine is not origianl and is a newer, 1956, 235 engine. Is that right?
1948 Chevy 2-Ton
I believe that is the casting number for the head and is a 235 number. I have the same number on the engine in my 54. has the oil gauge been upgraded to 60 lbs as well or does it still show 30 lbs? The inliners site has some good info as well as the vin decoder on this site. you should also have a stamped number on the block just behind the distrbutor above the starter.
Casting No., on the block, is located on the passenger side forward, of the starter.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
The block casting number looks like D 166, it is right above the starter. Between the starter and the distributer, on a machined surface the following numbers are stamped, 0910182 F55P3.Does this jive with the head number of 3836848. The oil pressure gauge is 30 lbs.
1948 Chevy 2-Ton
Super 55, okay we are getting closer but you need to go back to verify the 0910182 number.
It does not look correct, the first number would be 3.
Often times on casting numbers it is hard to tell a 3 from and 8 or a 2 might appear as a 7.
Try to rub the number off with a steel brush and see what you come up with.
Let me know and I will decode it for you.
Hobert
"The Lord is my shepherd"
Super55,
0910182 F55P3
0910182 is the engine unit serial number starting with 1001.
F = Flint engine plant (T = Tonawanda plant).
55 = year 1955
P3 = ??? P3 doesn't show as a good code...need help, check numbers again.
D 166 sounds like the cast date code.
D = April
16 = Day
6 = year (1956)
Could this be a dealer replacement done under warranty? The engine serial numbers we used for title purposes back then and the dealer may have transfered the original numbers to the replacement block to keep things correct for the owner. Do the number look hand stamped (not quite straingt or spacing off a little) or machine (everything in line and even)? Is this number on your title?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Here is a photo of the number stamped on the block. What I might have mistaken for 1's could be the letter " I " .
http://photoshare.shaw.ca/messages/viewimage/5655722166-1167933785-84210/preview/2492714/page/1/15
1948 Chevy 2-Ton
The number on the title is FEA54384 for the truck.
1948 Chevy 2-Ton
that number looks like an original engine number, which is prolly how the truck woulda been titled in 48, and the number on the current engine indicates a 55 [235]
So, Is the 235 a babbited engine? The truck is only suppose to have 34,000 miles on it. Wonder why it would have a replaced engine? Me thinks I have been too trusting. Well, at least I am getting to know the beast a little better. I don't think I'll be buying anything too big off of ebay again. Everything gets too rushed.
1948 Chevy 2-Ton
engine could have easily been blown in less than 34,000 miles with the right (or wrong) driver. I don't know how many people actually followed OEM maintenance schedules. My 38 owners manuel recommends 1000 mile oil changes and pulling wheel bearings evry5000 miles if i rememmber correctly. I'm glad oil and greases have been greatly improved
