3 members (JW51, Peggy M, 1 invisible), 63 guests, and 1 robot.
Topics128,050
Posts1,055,643
#1498658 04/28/2023 9:27 PM
8
nothing beats a try but a failure
8 Offline
I have been using acetone for panel prep. It evaporates to fast, what a waste. What other paint prep produces have you use?
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
87GN #1498665 04/28/2023 10:23 PM
Prep all
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
87GN #1498669 04/28/2023 10:50 PM
Acetone is too aggressive. It may soften the primer if you're using it over that.
I agree that Prep All is what to use. It doesn't evaporate in the time it takes to wipe down a panel.
87GN #1498673 04/28/2023 11:08 PM
8
8 Offline
Can prep all be made at home?
87GN #1498675 04/28/2023 11:11 PM
Bad Chad uses windex
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
87GN #1498676 04/28/2023 11:13 PM
I suppose you could make your own, but why go to the trouble. Just buy it at your FLAPS. O'Reilly's carries it. Link
87GN #1498692 04/29/2023 12:48 AM
7
7 Offline
PPG DX330 wax and grease remover for prior cleaning before sanding and general clean-up. Bare steel cleaning prior to shooting sealer should be an etching cleaner.
Wax and grease remover. It's suggested to use both water based and solvent based. Wipe it completely off. Paint companies also make a final wipe product.
