2 members (Shade Baby, tclederman), 111 guests, and 2 robots.
Topics128,141
Posts1,056,779
Members48,454
I seem to remember someone telling me to drill a small hole or two in my thermostat prior to reinstalling it. Sadly, I can't remember any of the details of size, location, or the reason for doing it. Please refresh my memory. Thanks
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
1/8 inch in the circular “disk” that opens/closes coolant flow.
1951 3100
Mike,
Perhaps this rather old thread on the subject may provide the memory jog you seek? thumbs_up
Dan
PS- There are several others, but this one is earlier than most.
~ Dan
1951 Chevy 3 window 3100
Some thermostats have a "jiggle pin" that allows air to vent while the cooling system is being filled, and closes the hole off as coolant starts to flow when the water pump starts it circulating.
AD Addict & Tinkerer
I drilled a 3/32” hole in mine. It purged the air out of the system and doesn’t seem to effect the cooling whatsoever.
Phil
Project Journals
Stovebolt Gallery Forum
If you don't have a small drill handy wedge an aspirin in the thermostat to hold it open and it will dissolve after purging the air from the system.
You Tube
