3 members (klhansen, ronsway, 1 invisible), 165 guests, and 1 robot.
Topics128,106
Posts1,056,213
Members48,436
#1497862 04/23/2023 11:10 PM
Any tips to remove stuck fuel tank drain plug with fuel in the tank?
O Online: Content
Drain the tank by putting a hose down the filler neck. Seal up the hose with a rag or whatever and put compressed air in next to it. The air will blow the fuel out the hose and into a bucket. Or siphon it the old fashioned way and get a mouthful of gas.
Are you replacing the tank? If so, just crank away with a long handled wrench and a persuader.
1950 Chevrolet 3100 (Ol' Roy)
Otto's trick works well to start a siphon. Once you have fuel running out the hose, as long as the end of the hose is below the bottom of the fuel tank, you can quit with the compressed air.
If you pull the drain plug with fuel in the tank, expect a gasoline shower. frown
Otto On siphoning use a not very big hose 1/4 inch fuel line,long enough to be in the fuel and hang down to the ground. Stand up full hight when you start your siphon, this way you wont even get fumes have your catch can on the ground. the next time you use it (few days) will be dry and ready to go again. Good way to do lawn mower fuel, with a big bolt can send it right in the mower.
Take a length of hose, on one end make a cut about 1/4 way through the hose about 1 inch from the end, from the front make a slice toward the cut so that you are removing a portion to make a triangular opening. Insert the other end into fuel tank. Insert hose exit end into a can, now place compressed air hose into triangle cut and blow lightly unto flow is started then remove compressed air hose.
1952 Chevy Pickup Truck
His question is how does he get the drain plug out, I’m assuming without heat, without ruining the tank.
With fuel in tank.
O Online: Content
Right, but the stuff that came out was full of rust so if the tank is being replaced, getting the plug out isn't necessary if it can be emptied.
I've siphoned out gas also using Otto's method. Don't need much compressed air--only enough to slightly pressurize the tank. Once the gas starts running, no more compressed air is needed.
Whether he's replacing the tank or not, it's much easier to work with and less mess if it can be emptied first.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Once that plug is out, I'd suggest a drain valve when you put it back together.
After draining mine multiple times for various reasons, i saw it's worth.....
Photo for visual aid.
1958 3100 Fleetside w/235 4spd
I see that valve is capped. Very wise precaution.
