| | | Forums66 Topics128,121 Posts1,056,328 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 192 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 192 | I am in process of getting radiator repaired and noticed after radiator was out there is a grease fitting on the water pump. Does it require a special grease? Thanks,Grady. | | | | | Joined: Oct 2021 Posts: 6,826 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,826 | And how often should that be greased?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2004 Posts: 29,808 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,808 | Any general purpose chassis grease will work, but be VERY stingy with the amount of grease you use- - - -too much grease has a bad habit of blowing out the pump seals. DO NOT use a pressure gun- - - -hand pump only, and only a little bit! Maybe every 6 months or so, depending on how much the engine is run. Jerry
| | | | | Joined: Oct 2021 Posts: 6,826 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,826 | How often should it be done or how do you know if it needs grease?
| | | | | Joined: Feb 2004 Posts: 29,808 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,808 | If the pump has ever been rebuilt, it's probably got the modern shaft, bearing, and mechanical seal assembly that runs permanently lubed sealed bearings. I haven't seen a water pump that needs greasing in about 50 years. Jerry
| | | | | Joined: Oct 2021 Posts: 6,826 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,826 | I know I've never seen one in my life. I'm going to go out and look at my truck to see if it has a fitting.
Nope. No fitting.
| | | | | Joined: Feb 2004 Posts: 29,808 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,808 | "If it ain't broke, don't try to fix it!" Jerry
| | | | | Joined: Oct 2021 Posts: 6,826 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,826 | "If it ain't broke, don't try to fix it!" Jerry I agree.
| | | | | Joined: Aug 2019 Posts: 192 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 192 | Thanks. I'll give it just a little as I've not greased it since I've owned truck. Bout 3 years. Who knew. | | |
