8 members (Maybellene, tclederman, RoadsScholar, DadsFirstPickup, baldeagle, MickeyP, Stovebolt48, 1 invisible), 198 guests, and 4 robots.
Topics128,108
Posts1,056,231
Members48,436
#1497609 04/22/2023 2:05 PM
I am in process of getting radiator repaired and noticed after radiator was out there is a grease fitting on the water pump. Does it require a special grease? Thanks,Grady.
1949 3100
Old Blue
O Online: Content
And how often should that be greased?
1950 Chevrolet 3100 (Ol' Roy)
Any general purpose chassis grease will work, but be VERY stingy with the amount of grease you use- - - -too much grease has a bad habit of blowing out the pump seals. DO NOT use a pressure gun- - - -hand pump only, and only a little bit! Maybe every 6 months or so, depending on how much the engine is run.
O Online: Content
How often should it be done or how do you know if it needs grease?
If the pump has ever been rebuilt, it's probably got the modern shaft, bearing, and mechanical seal assembly that runs permanently lubed sealed bearings. I haven't seen a water pump that needs greasing in about 50 years.
O Online: Content
I know I've never seen one in my life. I'm going to go out and look at my truck to see if it has a fitting.
Nope. No fitting.
"If it ain't broke, don't try to fix it!"
O Online: Content
I agree.
Thanks. I'll give it just a little as I've not greased it since I've owned truck. Bout 3 years. Who knew.
1949 3100
Old Blue
