7 members (tclederman, Gdads51, 1955 1 Series, moparguy, Gray_Ghost, Otto Skorzeny, 1 invisible), 75 guests, and 10 robots.
Topics128,078
Posts1,056,027
Members48,433
#1497527 04/21/2023 11:50 PM
I am beginning to install the new wiring harness in my 52 - 3100. Because it had no wiring when I got it, I don't know which holes wires should exit the cab into the firewall. There are a number of holes and I would love to try and get the new wires in their proper place. Any photos or help????
O Online: Content
Tomorrow I'll take a picture of my '50.
Basically, the wiring goes through the hole in the upper left corner of the firewall (driver side).
The other holes are for throttle and choke cables, oil sender tube, and speedo cable
1950 Chevrolet 3100 (Ol' Roy)
Here's a couple pics of my '51. Your truck should be similar. The main harness goes thru the large hole on the upper left of the firewall, and the feed from the starter goes thru the smaller hole toward the center.
FIREWALL LEFT SIDE
FIREWALL RIGHT SIDE
1947 3600 Chevy
O Online: Content
Here's a photo I already had of the voltage regulator. You can see the wiring in the upper right of the picture and the other grommets with the throttle and choke, etc.
Lower left corner of picture is vacuum wiper grommet.
Center left is throttle ,choke, temp and oil.
Center right is speedo.
I don't remember what's coming out of the hole next to the VR. I'll look tomorrow and take better pictures.
AD Addict & Tinkerer
Here is a picture from the Assembly Manual that show the penetrations.
Phil
Project Journals
Stovebolt Gallery Forum
O Online: Content
That's much better.
O Online: Content
Here are some pics of my firewall.
Otto, I appreciate the pix. Hope you are enjoying Ol'Roy.
Phak1 #1497715 04/23/2023 12:55 AM
Thanks so much for the diagram...making progress.
Lumbersawyer, Thanks for the photo with tags..
Thanks Kevin for the photos. Will try to post a picture when I am done with the firewall....
