0 members (),
93
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2022 Posts: 70 'Bolter | | 'Bolter Joined: May 2022 Posts: 70 | I’m rebuilding a 12 volt starter. Does anyone know the torque value for the four housing screws that hold the field coils in place? Several folks have told me “real tight” but in my book, that’s not the right answer.
Thanks, -Mike
1955 Chevy 2nd Series 3100 Stepside, 235cid
| | | | | Joined: Sep 2009 Posts: 5,989 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,989 | Mike, Found this current info page for Delco Remy straight drive starters that are for the most part modern versions of our earlier starters (someone can come along and correct me if I am wrong please): https://www.delcoremy.com/documents...embly-or-pole-shoe-package-replacem.aspxAppears to provide the current torque values for reassembly of these starters. Hope this is of some help.  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | You'll need a pole shoe vise to keep the screwdriver-shaped tool bottomed in the slot in the attaching screw, and a support strut inside the housing to keep from distorting it. You simply won't be able to put enough torque on the screw otherwise. I'd say a minimum of 40-50 ft.-lbs. will be required. Jerry
| | | | | Joined: May 2015 Posts: 11,142 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,142 | For those wondering what a pole shoe vice might be (me included), check post numbers 3-5 in this thread. Sorry, it's a Ferd forum, but the tools are similar.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | The tool is pretty universal, no matter what brand of starter or generator is being repaired. There's supposed to be a threaded expandable strut that's placed inside the housing to prevent collapsing or distorting it when pressure is exerted on the jackscrew to keep the tool in the slot while removing or installing the pole shoe screws. I started using that kind of tooling in the late 1950's in my father's shop. Jerry
| | | | | Joined: May 2022 Posts: 70 'Bolter | | 'Bolter Joined: May 2022 Posts: 70 | Wow! So much more than I thought. I agree that it will take a lot of pressure to keep the tooling firmly in the screw slot when torquing. Thanks for the Delco Remy reference and the additional guidance. I believe than a couple of guys in my “For*” club May have these tool, so I will reach out to them. If I show up on Saturday with a six pack, they’ll probably do cartwheels to help me. 😜.
Thanks for the advice & guidance. I’ll keep you posted. -Mike
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | A hydraulic press can be used as a field-expedient pole shoe vise, as long as you support the pole shoes from inside to avoid distorting the housing when applying pressure to the tooling. I have ground a drag link socket to fit the slot in the pole shoe screws and used a 1/2" drive T handle to turn it with pressure applied to the tool. Use a big Crescent wrench to hold the housing and keep it from turning while tightening the screws. Just be sure everything is set up perfectly vertical, and don't overdo it on the pressure! You can use a 1/2-13 "coupling nut" and two short bolts to make a support strut for the inside of the housing. Jerry
