| | | Forums66 Topics128,106 Posts1,056,211 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Anyone had some advice about drip rails install from experience...some tips, do's and don'ts ?? Looking for some things to keep from screwing up... The metal of the aftermarket seems soft do the spot back on or real easy to mess them up? Thanks! | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | If were to ever replace original or aftermarket drip rails, I would first install them with enough small self-tapping screws to form fit them to the cab. I would then remove them and use 3M panel adhesive to affix them permanently to the cab, using all of those screws to clamp the drip rail in place. Once the adhesive has cured, I would remove the screws and fill the holes with more panel adhesive. 3M panel adhesive is a miracle in a tube and easy to sand butter smooth, those rails will never come off.
