1 members (Peggy M), 95 guests, and 1 robot.
Topics128,101
Posts1,056,182
Members48,436
#1497354 04/20/2023 5:14 PM
V
V Offline
Anyone had some advice about drip rails install from experience...some tips, do's and don'ts ?? Looking for some things to keep from screwing up... The metal of the aftermarket seems soft do the spot back on or real easy to mess them up?
Thanks!
If were to ever replace original or aftermarket drip rails, I would first install them with enough small self-tapping screws to form fit them to the cab.
I would then remove them and use 3M panel adhesive to affix them permanently to the cab, using all of those screws to clamp the drip rail in place. Once the adhesive has cured, I would remove the screws and fill the holes with more panel adhesive.
3M panel adhesive is a miracle in a tube and easy to sand butter smooth, those rails will never come off.
