0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#1497014 04/18/2023 1:26 PM
Carburetion specialist
C Online: Content
I mentioned the TQ in another thread about carburetors, questions were asked, and not wanting to totally hijack the original thread, started this one.
The Carter TQ is a spread-bore design, and can generally be used as a replacement on a Chevy spread-bore intake, replacing a Rochester Q-Jet (quadrajet).
The TQ is a carburetor those building a performance V-8 should at least consider.
The initial release of the TQ was 5 February 1969. Two models were released: (1) 4847s (1000 CFM) and (2) the somewhat smaller 4846s (850 CFM).
The drag racers and weekend warriors loved the carburetor with one exception. Holley used O-rings for sealing on some of their fuel valves succesfully, so Carter tried using O-rings for sealing main metering jets and promoted the press-in jets for easy removal and installation. The jets were easy to remove, and NEW jets easy to install. What Carter didn't consider is that when racers dial in a carburetor, they may change jets several times. Once the press-in jet was installed, then removed, it was quite difficult (but still possible) to reinstall.
A clamor arose for conventional screw-in jets. Carter listened, and very shortly into the production run, new threaded castings, and new screw-in jets were introduced. The carburetor numbers were the same, but with an added "engineering change status". The 4846s became 4846sa, and the 4847s became 4847sa.
The 4846s and 4847s were the only TQ's to use the press-in jets; Carter had learned its lesson.
1969 was close to the beginning of smog emissions (1966 California, 1968 Federal), and Chrysler was using the smog developed AVS Carters on most V-8 applications in order to pass smog emissions. Since the thermoquads were more efficient than metal carburetors, Chrysler asked Carter to reduce the size of the TQ and de-tune it for the street. In 1971, Chrysler used the TQ on performance 340 CID engines only; wanted to test the TQ before committing entirely to its use. The 1971 340's were very successful, and in 1972 Chrysler discontinued the AVS on the 400 CID, and switched to the TQ. In 1973, Chrysler switched to the TQ on the 440 as well, so passenger 4-barrels were now TQ. Holley square-bore 4-barrels were continued on some truck applications.
TQ problems:
The worst issue with the TQ was the afore-mentioned press-in jets, but two additional issues arose.
(1) The initial "street" TQ's used an O-ring as a seal in the secondary well. Those familiar with Q-Jets can think of the Q-Jet well plugs. While these worked well in initial testing, they were found to leak in service on the street. Carter designed what they called a "quad X-ring". To understand, an O-ring is a ring from a material with the cross-section of the letter "O". And the "X-ring" is a ring of a material with the cross-section of the letter "X". Carter changed the part in new carburetors, and issued a recall for existing carbs to be modified at the dealers. This should have ended the issue, BUT: Carter revised the bill-of-material for factory rebuilding kits, and Chrysler obtained kits from Carter so the genuine Carter kits and the Chrysler kits had the X-rings. But everyone knows wink that dealer prices are too high so there is an aftermarket. When we started the manufacture of carburetor rebuilding kits for the thermoquad in about 1977, prices for manufacturer quantities of 1000 pieces of O-rings were 90 cents, and for X-rings $2000 !!! That is not a misprint. O-rings were less than 1/10 of a cent each, and X-rings $2.00 each in quantity. Guess what came in the aftermarket kits???
(2) The second issue was the "cracked plastic bowl" often with a few expletives added. Q-Jet rebuilders can identify with the cause of this problem. The home enthusiast wants to rebuild his TQ, so he acquires a kit, places in instructions under the parakeet cage, grabs his screw-driver and removes the 8 screws holding the TQ together. It doesn't come apart. Not wishing to damage the plastic, he shakes it, the taps it with the plastic handle of a screw-driver, finally with a plastic hammer. Nothing works, it still doesn't come apart. Now frustrated, he inserts a screw-driver between the bowl and the air horn and attempts to pry it apart, resulting in breaking the bowl. Now more than frustrated, he takes the carb to a mechanic, who opens the choke butterfly exposing the two additional screws that were shown on the diagram now somewhat messy from the parakeet wink So when asked about his TQ, does he tell his buddies about his experience? No, he tells them he had to replace a cracked bowl!
Should someone wish to use one of the TQ's on a Chevrolet V-8, there are 4 numbers to watch for:
(1) 4846s or sa (850 CFM manual choke) high performance/race
(2) 4847s or sa (1000 CFM manual choke) high performance/race
(3) 9800s (800 CFM electric choke) street performance
(4) 9810s (9800s modified with a pluggable EGR port)
From a Chevrolet standpoint, other numbers are merely parts sources.
Advantages versus a Q-Jet
(1) largest available spread-bore CFM
(2) Efficiency
(3) Weight - approximately 2 pounds less than a Q-Jet. This may sound trivial to some, but I spent thousands removing weight from my own playtoy, and it still basically appears stock
(4) Documentation - as the TQ was originally sold as aftermarket, Carter produced a LOT of tuning information, Rochester never did
(5) Parts availability - like (4) above, as the TQ was sold as aftermarket, a wide selection of tuning parts were available
Disadvantages:
(1) Parts availability (today) is somewhat worse than the Q-Jet, but is rumored there is a grumpy old hillbilly in Missouri that makes a lot of parts wink
(2) Knowledgeable mechanics - not too many TQ specialists left today
Jon
The Carburetor Shop
J Online: Content
Aside from the owner-induced “cracking,” did the plastic (phenolic?) parts survive the test of time? I.E. did they “age” ok?
1951 3100
C Online: Content
I have not personally seen any issues with the bowls; although I have been told that a couple plugs sometimes must be re-epoxied.
I have an 850 race carb (4846sa) on my own non-Chevy 350.
Jon
The Carburetor Shop
Thank you for moving this out to avoid a worse hijacking.
Did the Thermoquad have a similar really large primary/secondary ratio like the quadrajet?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
The TQ fits the exact same footprint as the Quadrajet. As I mentioned in the other thread, there's half a QJ known as a Dual Jet that has virtually the same engineering as the primary side of a QJ carb. It would be just about ideal for a stovebolt engine if a suitable intake manifold could be fabricated. Head and shoulders above any Rube Goldberg dual carb setup, and using carbs that are 40 years' newer production, plentiful and cheap!
C Online: Content
Yes, the primaries are much smaller than the secondaries.
TQ primary/secondary
800 CFM 200/600
850 CFM 250/600
1000 CFM 350/650
Jon
The Carburetor Shop
C Online: Content
Jerry - going to have to slightly disagree with you on the use of the Dual-Jet. Absolutely no disagreement on it being an excellent carburetor, and dirt-cheap (it is for two reasons).
Reason number 1 - documentation (there isn't any).
Reason number 2 - available tuning parts (there aren't any).
So if one were installed and the calibration was close, it would be a great carburetor. If the calibration is not close, one better have a really good machine shop, and know how to use it; or the Dual-Jet would be a door-stop.
Jon
The Carburetor Shop
Authorized Pest
Authorized Pest
Was asked:
Quote
Would it make sense to kick this over to HiPo with the other 2bbl upgrade thread? I am not clear on where the line is drawn between upgrades and hipo for engine parts.
There's no hard and fast rule with some things in here. Whatever gets the best responses is sometimes the rule of thumb. Another rule is where do people FIND it, when they are looking for certain things.
So, this is a good question. There is a good discussion going on in Engines. But ... let's see. I'm gonna move this to HiPo. If there is any angst about it, just "flag me" and I'll move it back.
headscratch
~ Peggy M
1949 Chevrolet 3804
Jon, the primary side parts for a QJ are pretty much interchangeable with the dual jet carbs I've tinkered with- - - -main jets, metering rods, etc. Having a 4-gas exhaust analyzer and enough knowledge to use it comes in handy, especially when it's combined with a 120 volt AC inverter for real time analysis on a road test. It's also pretty simple to make minor changes in high speed mixture by tinkering with the float level a little.
C Online: Content
Jerry - most home enthusiasts unfortunately do not have the luxury of the 4-gas analyzer.
With the Q-Jets, there are, from memory, three different primary rod profiles (DEFINITELY NOT INTERCHANGABLE) from 1965 to about 1979. There is some documentation of these in the aftermarket. Cliff Ruggles (Mr. Q-Jet) has made a lot of this infomation available from his experience with Q-Jets. There is also a bit of documentation on primary rods (much more on the secondary rods) in the Doug Roe book. I don't know what profiles the newer Q-Jets use, very little documentation that I know of; and I am unaware of any documentation on the Dual-Jets.
I guess it is just a difference in approach. If one has the analyzer and the time, one can physically test; which obviously is the best approach.
But if one does NOT have the analyzer; but being able to pull a sheet on the carburetor in question, and study the metering components allows one to mathematically determine changes that should work.
If one looks at the major automobile carburetor companies since WW-II: Carter, Holley, and Stromberg ALL offered retail aftermarket carburetors. Autolite and Rochester did not do so. If one looks at the documentation available: Carter, Holley (up to about 1960) and Stromberg is great. Holley after 1960 and Rochester is fair, and Autolite is, well, less than fair. To be fair, Rochester's documentation is much better from 1949 to about 1957 than after 1957. Also, Stromberg documentation newer than 1970 is about like that of Rochester.
Jon
The Carburetor Shop
I suppose what seems to be routine tinkering to us round track racers becomes voodoo magic to others. I've made half a dozen mixture changes in one afternoon, getting ready for the evening's main event- - - -a major change in humidity and/or atmospheric pressure from a thunderstorm passing by a few miles away might require a few main jet changes in the span of 3 or 4 hours. Just an integral part of playing the "go fast-turn left" game! We also made precision adjustments to the fuel mix- - - -by changing the number of 6 ounce Coke bottles of water we added to an 8-gallon beer keg tank of alcohol and Hydrogen peroxide, depending on humidity!
