4 members (Gdads51, Rustnut, Otto Skorzeny, 3800GUY), 96 guests, and 3 robots.
Topics128,079
Posts1,056,301
Members48,441
Anyone using a additive to your transmission. If so please post name and make of the additive.
Doug
[email protected]
Crusing in the Passing Lane
Why?
Ed
Just asking. Wondering if any one is using a additive.
dougs Don't need one ,you'll hurt the synchronizer action.
So what wt oil oil should be used in SM420 transmission that will not effect the synchronizer?
Doug
90 weight straight mineral oil- - - -Tractor Supply sells it as Ford tractor transmission fluid. DO NOT use synthetic lubes of any kind or weight such as 85W-140, for instance. They're too slippery, and will cause gear clashing during shifting.
O Online: Content
How is 85w-140 too slippery? It seems the high viscosity would be anything but slippery as long as it isn't synthetic.
1950 Chevrolet 3100 (Ol' Roy)
Doug,
Just a note that I have moved your thread and conversation to the Driveline forum as the best place to further discuss this topic.
In respect to your question about what weight oil should be used in an SM420 transmission, that has been discussed quite often. You could use the Search The Site tool found in the left margin to see many of the threads on the topic that already exist.
Otherwise, have you looked in any of the easily found sources like original/reprinted and even on-line copies of owners manuals and Service Manuals???
See below for a screen shot of an "Owners Manual" page concerning transmission lubricants to be used (Note: this was taken from a '48 Chevy Truck Owners Manual, but is the same for your '49).
I also wonder why you asked about using an "additive"???
Hope this helps.
Dan
Rear axle and transmission lubricant data 1948 Chevy Truck Owner's Manual.png (249.28 KB, 127 downloads)
Transmission lubricant data
~ Dan
1951 Chevy 3 window 3100
This is whats been in my 3 speed with borg warner OD for years now. Zero complaints or problems. All original everything and shifts like butter. TSC 90 Mineral Oil
RLB Offline
The mineral oil sounds like a good way to go. Pennzoil still sells a GL-3 grade gear oil that would probably work well too. I just picked up a qt of 90 wt at the local Napa store for the M20 Muncie 4 speed in my C10.
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
