8 members (MRMEROTH11, Peggy M, Southerntruck, Jon G, Ponchogl, Oswald, moparguy, Hanks custodian), 123 guests, and 0 robots.
Topics128,068
Posts1,055,880
Members48,428
#1496657 04/15/2023 9:39 PM
I was wanting to know the bolt pattern of a 1946 Chevy 1/2 ton truck. What years will fit the 46? I am looking for rims. The ones we have are rusted around the bead. Thanks
Hank
Hank,
Here is a screen shot of the original 1946 wheel specs from the GM Heritage site 1946 Truck Data.
I know this doesn't fully answer what will fit, just what was there originally.
I am sure others will jump in here soon and try and add some more info or replies to help answer your question.
When you do figure out for sure what you want to find/buy, be sure to post an ad in the Truck Parts Wanted forum .
Dan
3100 1-2 ton Wheel and Tire diensions 1946-Chevrolet-Truck.pdf.png (43.81 KB, 145 downloads)
1946 Wheel and Tire Data
~ Dan
1951 Chevy 3 window 3100
Thanks for the info Dan. It came with 15's on it but I have one that will not hold air.
The rims for the 46 would be the same for the AD Series. 6 lug 5 1/2 spacing. I am not familiar enough with model years prior to 41. Whether you have 15” or 16” rims the following specifications should apply:
Tire size and ply rating
6.0-16-6
Rim size
16 x 4-1/2
Offset
9/16
7/16-20 bolts, 5-1/2 bolt circle
I assume the offset and back spacing are the same seeing that hubs interchange.
1946 GMC Project
"Back-in-the-day Restore"
Thanks Tom for the information. I was told by a friend that farmers would put 15's on the truck because they wanted more rubber where city trucks had 16's with less rubber. How true that is hard telling. We have an old farm truck from Kansas
Hank
Definitely post some pictures.
1946 GMC Project
Here you go Tom.
Hog Wild what it that canister on the drivers side running board? I have a 46 "patina" truck also but mine doesn't have that.
Bob
1946 Chevy 1/2 ton "patina" pickup with a 1953 235 engine, otherwise all stock and unmolested!
