5 members (WICruiser, Gdads51, 55shaker, Ponchogl, DadsFirstPickup), 121 guests, and 1 robot.
Topics128,054
Posts1,055,782
#1496210 04/11/2023 10:16 PM
8
nothing beats a try but a failure
8 Offline
I'm beginning to do body filler on the epoxy primer. 2 questions, 1 - how do I detect moisture in the urethane primer and also body filler? 2 - how would I remove the moisture?
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
87GN #1496223 04/12/2023 12:24 AM
back yard wrench turner
The primer shouldn't have any you can use a moisture meter to detect it.
https://www.amazon.com/Digital-Mois...&hvtargid=pla-1636494276148&th=1
If you have moisture in the filler, grind it off and start over. Seal your filler soon after it's set up to prevent moisture.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
87GN #1496239 04/12/2023 2:48 AM
Moisture in the compressed air can contaminate primer. Are you draining your compressor regularly and using an inline filter upstream of the spray gun?
87GN #1496250 04/12/2023 11:55 AM
8
8 Offline
I do drain the tank every morning. But I never thought to use the filter. I use the filter to spray. I am going to buy a batch of in line filters.
87GN #1496279 04/12/2023 3:33 PM
If you have a moisturizer problem like here in Florida, you might try to condense the water from the air after it leaves the tank and before it enters the moisturizer filter by using a manifold of copper pipes with drains at the bottom.
Mike
1940 Chevy 1/2 Ton presently... Almost done
1940 Chevy Business Coupe... In pieces
87GN #1496295 04/12/2023 5:44 PM
My compressor has a moisture separator filter/regulator on it, which does a pretty good job of removing the moisture, but the air here in Alaska is generally drier than a popcorn fart. wink
Even so, I use another filter right at the gun, and haven't had any problems with moisture in the air. A friend built a condenser setup on his compressor like Mike suggested. Another option is to put a coil of copper that the air runs through in a bucket of cold water.
If you're really concerned about moisture in primer, you would need a big oven to bake parts in. Heat will drive moisture out.
87GN #1496330 04/12/2023 11:17 PM
7
7 Offline
Run the air conditioning in the shop, that will dehumidify better than anything else.
87GN #1496342 04/13/2023 12:34 AM
On the expensive side is a refrigerated air drier.
My homemade dryer is a coil of hard plastic hose. 5 or 6 turns. They are cooled by air with the bottom of the turns collecting moisture. The last turn has a drain valve on a T plumbed in.
