6 members (cmayna, Gdads51, 3B, moparguy, MickeyP, JW51), 110 guests, and 3 robots.
Topics128,064
Posts1,055,861
Members48,428
#1496058 04/10/2023 4:38 PM
Grease Junkie
Grease Junkie
49 3600
I was lucky enough to find a 4.10 differential to replace my original 4.57 gear set. So, I've been having to rely on a GPS to avoid speeding tickets. I'd like to swap the original #3689178 speedometer gears in my SM420 with #3689223 gears from a 1/2 ton. That should get me close enough on the final drive ratio to ditch the GPS.
My question is (and yes, probably a stupid one) can I just pop out the original 13 tooth driven gear an pop in the 12 tooth gear or do I need to swap the drive gear too. I ask because the drive gears in both sets have 4 teeth.
Thanks in advance,
Steve
1949 3600 w/ 57 235
I don't really think, either way, weather your speedometer is 5 mph off or so, at 60 mph that your going to overwhelm the local "Barney Fife" wannabe. There are alot of other idiots out there that attract way more attention than a 70+ year old truck scooting through town at a high rate of speed, with total disregard to the posted speed limits. Well, unless we are in Mayberry... Lol... Don't worry. Someone will have the appropriate answer to your dilemma. But if they don't, you'll probably still be under the radar.😁
If you don't want to mess with speedometer gears you can calculate the percentage your current setup is out and buy a ratio adaptor like this and put it in-line.
https://transmissioncenter.net/shop/ratio-adapter-other-ratios-available-call-jim-1-888-201-2066/
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Jim Carter offers a speedometer ratio adapter, it is the $125. ……external solution, follow 50mph ordering instructions, then connect…..
Just dont change your rear tire diameter………
Hah, mike beat me by a minute…
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
Crusing in the Passing Lane
Or one can just check the speed difference with highway mileposts and clock, remember percent difference and figure out true mileage while cruising along?
Ed
C Online: Content
I use a ratio adapter which I got from a local speedometer shop a few years ago. Still running perfectly.
Craig
Grease Junkie
Grease Junkie
I'll reply to my original post here. I asked if I could just plug in a 12 tooth driven gear to replace the original 13 tooth gear without also replacing the drive gear. I tried it and the answer is "NO". If you need to change the speedometer gears to match a change in differential ratio or tire size you must change the speedometer gears as a set. so, anybody out there know where I can get a GM 3689223 gear set?
1949 3600 w/ 57 235
Might be easier and cheaper to find a speedometer adapter with a 12 to 13 gearset.
