0 members (),
143
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 7 Junior Member | | Junior Member Joined: Aug 2005 Posts: 7 | I have located a small block Chevy (1965 283) to replace the 216 in my 1949 4100. Does anyone have any experience with this swap. What am I in for regarding the motor mounts, cross member, bell housing, or radiator clearance. Any advice welcome. The brakes have already been completely rebuilt. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Nice move covering the brakes first!
I have seen several small blocks installed in big bolts and in most ways its not much different than putting one in a pickup.
Do you intend to leave the existing transmission in place? If so you need a V-8 type bellhousing from a '55 to '67 V-8 truck, or '63 to '67 six. The mounts on the bellhousing are different than your '49 and you'll either need to make adapters or swap to a '54 or '55 1st 4100 crossmember.
You'll have exhaust manifold/steering interfence.
The common V-8 swap crossmember available from most the venders is probably the easiest way to mount the front of the motor.
The radiator will be further from the fan than on a stock six. You may need to deal with that if it gets too hot. If not, ignore it.
One other thing to be aware of is that your '65 motor should have early heads and does not have the front mounting holes for the alternator and other accessories.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2005 Posts: 7 Junior Member | | Junior Member Joined: Aug 2005 Posts: 7 | Thanks for the info. I will be looking for the appropriate bell housing. I've heard that old Camaro headers will clear the steering box. Have you run across any other solutions.
Happy Holidays! | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | A left side '55 V-8 exhaust manifold is supposed to clear the steering box and has the pad to mount your generator or alternator on. A little restrictive,but for a truck that won't matter. Speed | | |
