1 members (rick46ia), 218 guests, and 0 robots.
Topics128,080
Posts1,056,060
Members48,433
#1495257 04/04/2023 8:36 PM
8
nothing beats a try but a failure
8 Offline
Has anyone used Eastwood’s Fast Etch. Reason I am asking is the zinc phosphate does not come off. I used Eastwood’s Pre and acetone. Only some of the phosphate came off.
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
87GN #1495478 04/06/2023 6:52 AM
A solvent based cleaner will not effectively remove the ZnPh. Water and soap will be your friends. I am assuming that you applied zinc phosphate to the metal as a pre-primer.
1946 GMC Project
"Back-in-the-day Restore"
87GN #1495494 04/06/2023 12:07 PM
8
8 Offline
Humidity is back in Maryland. ZnPh was used to stop the surface rust.
87GN #1495532 04/06/2023 3:32 PM
When it dries, it tends to leave a light powdery residue or zinc layer.
That residue prevents good primer adhesion therefore it’s best to remove it. However…, (and this has worked for me… try it on scrap…):
I apply the ZnP and keep it wet , build up a couple coats and eventually it will lightly adhere to the metal without the powdery coat, and dry as a nice coating (and not as the powder residue.)
I have successfully primed over that with good adhesion.
If humidity is becoming a problem - rubbing down with alcohol will remove any possible moisture, or a light rub down with lacquer thinner just prior to priming too. Eastwood’s “ Pre” will assist with that after you prime or before laying down the topcoat.
1946 GMC Project
87GN #1495597 04/06/2023 9:56 PM
8
8 Offline
So I did go out today and try your suggestion which was use soap and water. I mixed up some Dawn and water in a spray bottle and wash a 2'sq spot on the back of the cab. It did come off leaving a hint of fast etch.
87GN #1495660 04/07/2023 1:24 PM
I also use the zinc Ph as a wet/dry paper lubricant when a project seems to not be a complete strip the old paint off to bare metal, but rather smaller sheetmetal items that have had scratches or paint rub off - and surface rust has appeared.
This saves a lot of time - working the Zn Ph in through the grits and blending the scratched perimeters to the existing paint areas.
It’s then a matter of touch up with primer, sand and blend again, then overspray the entire item or piece with topcoat paint. Of course test a small area to ensure the topcoat won’t lift or crinkle the old paint. If it does…oh, well it would have been a strip, fill, prime and paint project then.
Using the ZnPh with the grits on the rusted area works it into the small divots and is happily offloading ions and working through an over my head chemical reaction where electrons are being gained, and someone somewhere did the math through a balancing equation; joyously etching away as you work on other areas.
I am doing this now on an antique drill press cover but have had great results on engine valve covers and similar sheetmetal items including AD dashboards.
Up here in NH, a little warmth and humidity would be welcomed. Snow on the ground yet. Winters are long, and the spring slow.
Take care.
Tom
1946 GMC Project
87GN #1495684 04/07/2023 3:41 PM
8
8 Offline
Thanks Tom. I will heat the shed to lower the humidity. Wash with soap and water. Followed by acetone. Apply epoxy.
