| | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 17 Junior Member | | Junior Member Joined: Nov 2005 Posts: 17 | I've got a couple spots that won't take grease even after I've replaced the fitting. They haven't been greased in a while and it looks like the grease is all dried up inside. What do you do here short of taking it apart? I've tried spraying degreaser etc. to try to soften it. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Take out the fitting & spray the degreaser as you dig inside with an ice pick. Fill the cavity up with the degreaser & put the fitting in. If that doesn,t work try heating it up. Sometimes you do have to take them apart. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2005 Posts: 17 Junior Member | | Junior Member Joined: Nov 2005 Posts: 17 | Thanks, I didn't think about heat. I'll try it. | | | | | Joined: Nov 2006 Posts: 31 Junior Member | | Junior Member Joined: Nov 2006 Posts: 31 | drill bits are good for digging out grease and grime. | | |
