7 members (mo2cyl, 1955 1 Series, FAST55, Steelonsteel, MikeE, sron48, klhansen), 91 guests, and 3 robots.
Topics128,050
Posts1,055,667
#149553 12/18/2006 11:43 PM
Junior Member
Junior Member
I've got a couple spots that won't take grease even after I've replaced the fitting. They haven't been greased in a while and it looks like the grease is all dried up inside. What do you do here short of taking it apart? I've tried spraying degreaser etc. to try to soften it.
#149554 12/19/2006 12:40 AM
Riding in the Passing Lane
Take out the fitting & spray the degreaser as you dig inside with an ice pick. Fill the cavity up with the degreaser & put the fitting in. If that doesn,t work try heating it up. Sometimes you do have to take them apart.
1972 Chevy c10 Cheyenne Super
#149555 12/19/2006 2:46 AM
Junior Member
Junior Member
Thanks, I didn't think about heat. I'll try it.
#149556 12/19/2006 1:13 PM
I
Junior Member
Junior Member
I Offline
drill bits are good for digging out grease and grime.
