1 members (RLB),
81
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,940 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I am going to change the oil in my rear differential. I am not sure if I can come up with a replacement gasket. If not, what gasket in a tube do you guys use. Will just the gasket silicone stuff in a tube work by itself as a gasket. The common Permatex brand comes in the blue and black. Which would be best for the differential cover. | | | | | Joined: Oct 2021 Posts: 6,934 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,934 | I figure if Permatex Grey or Black works on intake manifolds, it's probably fine for a rear diff.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | Dave, Rock Auto has the gaskets available: Differential cover gasketDan EDIT: Moved this to the "Driveline" forum for further discussion as the better forum for subject.
Last edited by Gdads51; 04/04/2023 2:17 PM. Reason: Relocation of thread to Driveline forum
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jul 2000 Posts: 2,200 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,200 | I suppose you could just suck out the old oil like the quicky oil change places do....
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | I have used permatex black for decades without any issues. It is harder to clean off than a gasket the next time you open it, but it also doesn't leak after a year or two. | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I was considering sucking out the old oil but I guess this would be a good opportunity to get the sludge out and inspect the gears. I also hope to never have to do it again. I don't think I will be around when it is due for a change in 50 years. | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | It only takes a few minutes to whittle out a rear cover gasket, using a file folder, scissors, and an X-acto knife or box cutter. Brush on a coat of Permatex Super 300 for sealer. I used to use sharpened .38 Special cartridge cases to cut out bolt holes, but now I've got a gasket punch set. Jerry
| | | | | Joined: Oct 2012 Posts: 340 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 340 | Permatex "green" is for gear oil, but as others have said grey or black will work also
1936 GMC T-14 restro-mod
