0 members (), 133 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
#1495185 04/04/2023 1:27 PM
I am going to change the oil in my rear differential. I am not sure if I can come up with a replacement gasket. If not, what gasket in a tube do you guys use. Will just the gasket silicone stuff in a tube work by itself as a gasket. The common Permatex brand comes in the blue and black. Which would be best for the differential cover.
Dave from Northern Kentucky
My 54 3100
I figure if Permatex Grey or Black works on intake manifolds, it's probably fine for a rear diff.
1950 Chevrolet 3100 (Ol' Roy)
Dave,
Rock Auto has the gaskets available:
Differential cover gasket
Dan
EDIT: Moved this to the "Driveline" forum for further discussion as the better forum for subject.
Last edited by Gdads51; 04/04/2023 2:17 PM. Reason: Relocation of thread to Driveline forum
~ Dan
1951 Chevy 3 window 3100
Insomniac
Insomniac
I suppose you could just suck out the old oil like the quicky oil change places do....
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I have used permatex black for decades without any issues. It is harder to clean off than a gasket the next time you open it, but it also doesn't leak after a year or two.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I was considering sucking out the old oil but I guess this would be a good opportunity to get the sludge out and inspect the gears. I also hope to never have to do it again. I don't think I will be around when it is due for a change in 50 years.
My 54 3100
It only takes a few minutes to whittle out a rear cover gasket, using a file folder, scissors, and an X-acto knife or box cutter. Brush on a coat of Permatex Super 300 for sealer. I used to use sharpened .38 Special cartridge cases to cut out bolt holes, but now I've got a gasket punch set.
Permatex "green" is for gear oil, but as others have said grey or black will work also
1936 GMC T-14 restro-mod
