2 members (78buckshot, 1955 1 Series), 114 guests, and 2 robots.
Topics128,062
Posts1,055,857
Members48,428
I
Retired Construction Worker
I Offline
Here is the question ,,Will testing one cylinder for preasure tell you that either the other 5 is about the same ? or could one cylinder be fine and another real bad? What are the odds of one cylinder being bad when the motor is not buring oil which would mean bad rings for example
Directions are just another man's Opinion
Try testing compression on cylinder #1 when the #5 piston has a big hole in it. All the cylinders must be tested, and a percentage variation between them needs to be calculated. Compression tests in general are a very primitive way of monitoring the condition of the cylinders. A leakdown test where air pressure is introduced into the cylinder with the crankshaft locked is a much better indicator of the mechanical condition of the piston rings, valves, head gasket, etc. Depending on the skill of the operator and the testing procedure he uses, a compression test is sort of a "measure with a micrometer, mark with chalk, and cut with an ax" process. It's better than nothing, but not much.
I
I Offline
This explains it very well .. I was curious and not needing to do it ,, thx Jerry
idaho,
Just a chime in here in case you hadn't checked yet. Here is just a sample of many available "engine leak down tester" available (not mine nor can I vouch for if this one as a good value or not) at an inexpensive price should you decide to do the testing yourself:
https://www.amazon.com/Cylinder-Automotive-Pressure-Compression-Detector/dp/B09T38YCVL/
Perhaps others will come along and add their wisdom???
See below pics for my "old school engine tester" found amongst the boxes of spare parts and tools I got along with my Grandfather's '51 many years ago. wink
Dan
Old School Motor Tester (box)
Old School Motor Tester (tool)
Old School Motor Tester (instructions)
~ Dan
1951 Chevy 3 window 3100
Authorized Pest
Authorized Pest
Can't help it, Walmart fan.
Cylinder Leak Down Tester Engine Co...ge Test Set for Gasoline Engine . $29.99
wink
Order $5.01 more and free shipping. thumbs_up
~ Peggy M
1949 Chevrolet 3804
Alternatively Autozone will loan you one for free.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Authorized Pest
Authorized Pest
That's even better! grin
~ Peggy M
1949 Chevrolet 3804
"Free" means you leave a theoretically refundable deposit equal to the value of the tester and get it back when the tool is returned. How accurate it might be depends on how badly it was abused by the last guy who used it. I don't know about anybody else, but I'm pretty selective about who uses my hand tools, let alone my precision test equipment.
Authorized Pest
Authorized Pest
Well, several choices.
Plus, if you knew a Bolter nearby ... Maybe. wink
~ Peggy M
1949 Chevrolet 3804
I
I Offline
Thx to all of you ,,,,,,,,,,,for the explaining of how one should test compression on an engine the correct way and also what tool and where to get one.. I was curious and now I know ,,and one day when I sell my old stove bolt Car I will use these great ideas here if needed ,or share it with the new owner.
A leakdown tester doesn't need to be complicated, although the kit in the link is handy and inexpensive. I just use an adjustable air pressure regulator from Harbor Freight and a spark plug shell with an air hose quick connect nipple soldered into it. Adjust the regulator to 100 PSI on the built-in gauge with no air flowing, and plug the air hose onto the adapter screwed into the spark plug hole. If the pressurized cylinder holds 90 PSI, for instance, there's a 10% leakdown rate. A cylinder with good piston rings, valve seats, and a head gasket that's not leaking should hold pressure in the 90%+ range. Listen at the carburetor, tailpipe, or crankcase filler to determine where the leakage is. A leaky head gasket or a cracked cylinder head will cause bubbles in the radiator.
Last time I did a compression test on the green turd was in 2015. Been wanting to do another test but remembered something about doing a leakdown test instead. Thanks to all for the reminder comments and suggestions.
Craig
1 Offline
Do a compression test in conjunction with other assessments, such as evidence of blow-by, oil consumption, power on the road, etc.
For example, on my trip south winter of '22 the engine began using oil which got worse as the trip progressed. Downwind of the road-draft tube was a mess of mixed oil and dust. Power wasn't down much but some. By the time I got home it was using a quart in 300 miles. I did a compression test and compared it to previous tests. No. 6 cylinder was down to 110 pounds from its previous 135, while the highest was 140. Previously, no. 5 was the lowest at 120 from a scratch in the cylinder wall that occurred somewhere in the past. The plugs showed no signs of oil burning. Given 200,000 + miles on the shortblock I decided to pull it apart. No. 6 piston was burned back about 1/2 inch from the edge and about an inch long yet it still showed 110lbs but there was a lot of blowby blowing oil with it out the vents.
Oil in the cylinders from leaking oil rings can mask worn rings by still showing normal cylinder pressures on the compression test. Likewise leaking valve-stem seals.
1951 3800 1-ton
In the DITY Gallery
Just to add to Jerry's statement. I see it as a generic comp test tells you if there is a problem. The leak down test tells you where the problem is. I knew nothing about the leak down tester until I borrowed one and watched some videos how to do it.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
