| | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | Has anyone tried the expansion foam that supposedly does not push to sound deaden the A B pillars, cavity between tank and Window? I'd like to try it, but am scared.
Even thinking about the cavity between the inner and outer roof?
| | | | | Joined: Sep 2010 Posts: 2,306 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,306 | There are two types if you use the type used for insulating windows it does not have as much force. | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Something to consider Expanding foam products for construction come in many variations and some are open cell while other are closed cell
Both open and closed can get water logged, but closed cell takes much longer to soak in water All foams once water logged cannot be dried out and must be cut out, my dad had a old panel van that was foam insulated and the foam didn’t stop condensation from penetrating the foam to the back side of the metal body and this lead to massive rusting out of the whole vehicle in a decade.
Since this foam would be acting like it’s own vapor barrier I would only consider a closed cell type for in a car
All the single can foam products are open cell You need a kit that mixes two products in the nozzle to get closed cell foams They are highly exothermic but spraying in metal you should be fine. -s | | | | | Joined: Sep 2020 Posts: 438 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 438 | Consider that foam may trap moisture, either from water intrusion or condensing. If you use sound deadening pads you will get significant improvement, removing the tank to install if necessary, in the pillars will offer less result as those areas are small and tight which resonate less. Larger the span the more it resonates. Summit has their own brand peel and stick rubber/alum pad kit that priced out well. Still have extra laying around.
When I did inside the door panels, floors, firewall, and cab rear lower half I got significant results, if I had done behind/above the headliner I would expect added reduction (is added reduction and oxymoron? How about further reduction) The doors sound more solid than I expected when they close instead of tinny, even though I did not do the outer skin (so they could breathe).
Chuck
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | I don't think completely filling void is necessary. Just getting a few areas will stop the resonance I think. I am very happy with how thuddy the floor and rear is up to the top of where the tank goes. As soon as you start tapping high in the B pillar you can hear it vibrating. Same with the roof.
If a guy didn't fill it completely air could still circulate and dry if any moisture got in there. | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | If you're just trying to take the "ring" (like a bell) out of a panel, just about anything that can be stuck to the center of it will work. I've seen where they just took a glob of roofing tar (or something similar) and smeared it on the underside of the panel. Roofing tar probably wouldn't be the best choice.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2018 Posts: 72 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 72 | I had mine sprayed with fluid film, inside doors, rockers, roof, window killers, everywhere he could get. Truck sounds much more solid, all tinny sounds gone, more quiet going down the road and I don't have to worry about rust starting on the inside of all my new panels. | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | What is fluid film in this context? | | | | | Joined: Jul 2018 Posts: 72 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 72 | Took care of the ring, tinny sound, truck is much quieter. NO moisture issues. We use spray foam a lot in my trade, it is highly over rated. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | They make a product just for this app called Lizard Skin.
Evan
| | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | Took care of the ring, tinny sound, truck is much quieter. NO moisture issues. We use spray foam a lot in my trade, it is highly over rated. Never would have guessed that fluid film would deaden sound. Would be super easy to get it in places impossible to access with other products.
1951 3100
| | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | Took care of the ring, tinny sound, truck is much quieter. NO moisture issues. We use spray foam a lot in my trade, it is highly over rated.[/quote]
That being said I can easily build a flex hose (spray 360) for some undercoating to be sprayed into these areas. Once bonded it would not absorb moisture? | | | | | Joined: Jul 2018 Posts: 72 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 72 | Yes, you can buy everything needed to spray it, a small hole in the doors and a plug . In the roof area we went in thru the rearview mirror hole and sunrises holes, about a three foot hose with 360 spray. I was impressed. I don't think there is anywhere you can't get it. It is impressive stuff. | | | | | Joined: May 2005 Posts: 281 'Bolter | | 'Bolter Joined: May 2005 Posts: 281 | I used ABESCO fire stop expanding foam to seal the openings between the engine compartment and the rear quarter panels on my VW beetle. That was 15 years ago and there is no evidence of rust and it is an effective seal. This foam has very little water absorption and is typically used to seal around ducts and electrical conduits in fire rated walls and floors. I'm not sure I would use it to completely fill a cavity but it expands to fill a large opening similar to Great Stuff. It is not the same as Great Stuff. The two part foam would be better if you need to fill a sizable cavity but I don't know about it's flammability.
Mark | | | | | Joined: Jul 2018 Posts: 72 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 72 | Here in northeast Pennsylvania water absorption equals rust, why I used fluid film. Unexpected benefit was sound reading in those areas, roof, doors, box sides even hood area. My guy is a professional and I am very happy with the results. It even surprised him, I think I'm the only one that would a vehicle 50 plus years old and fluid film it. | | |
