6 members (Otto Skorzeny, Jay R, Eisenholtz, Shardean, Gdads51, rick46ia), 93 guests, and 2 robots.
Topics128,023
Posts1,055,366
Members48,420
#1494957 04/02/2023 5:24 PM
I have a 41 AK 6 volt w/Lectro Lock ignition. There is a short in the armored cable at the firewall. Can it be fixed? If so, who has the secret?
ronsway,
Although I haven't ever worked on an Electrolock switch unit before, a little web searching came across these links to possibly relevant bits of info (a bunch of reading) that may help you fix your short.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1140669/Re:_Electrolock_wire_replaceme.html
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1366558/1939-vc-6-volt-electrolock.html
https://www.chevytalk.org/fusionbb/showtopic.php?tid/209339/
http://hudsonterraplane.com/tech/1929/1929Hudson-EssexElectrolockInfo.pdf *
* Although not specific to Chevy's, thought the general detailed testing and service info might be of some use.
Grab a cup of coffee, there is a good bit of reading in here.
Dan
Electrolock part number data 1929-41 Chevrolet Master Parts.png (630.17 KB, 43 downloads)
Electroclock part number data
~ Dan
1951 Chevy 3 window 3100
