1 members (TooMany2count),
81
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 6 Junior Member | | Junior Member Joined: Dec 2006 Posts: 6 | Does anybody have a guess as to the GAWR on a '49 3800 Dually? The springs are getting tired and I want to replace them with whatever the axle can handle. That way when the overloads hit, I know that it is about time to stop loading. Right now the overloads are only about 1/4"-1/2" from touching when empty. Too much spring would let me overload the axle before the springs hit.
I'm thinking at least 7,000. The current tires can handle 9,600. I think the truck is an 8,800 GVWR. | | | | | Joined: Dec 2006 Posts: 6 Junior Member | | Junior Member Joined: Dec 2006 Posts: 6 | | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | On a '49 GMC 1 ton 250 series 8800lb. GVW (which is the same as the 3800 1 ton Chevy)The axle weight rating is 3500lb. frt., & 7200lb. rear. Hope this helps. | | | | | Joined: Dec 2006 Posts: 6 Junior Member | | Junior Member Joined: Dec 2006 Posts: 6 | | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Spanky, is that the same whether it's a duallie or single rear wheels?
Thanks, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | |
