7 members (Shardean, DannyW, 68ironhead, Eisenholtz, 3800GUY, Shade Baby, cmayna),
40
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14947 02/04/2003 3:02 AM | Joined: Feb 2003 Posts: 29 Junior Member | | Junior Member Joined: Feb 2003 Posts: 29 | I've just inherited my grandpas 66 chevy c10 fleetside. Has a stock 250 6 cylinder. Wanting to put a v8 and auto trans in place of the standard shift and 6, but...how do I know what will bolt up properly..have done minor mechanical work, but never swapped an engine. | | |
#14948 02/04/2003 4:14 AM | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | Welcome to the stovebolt site!
This year of pickup is as old as I am but it a little to new for me to be of much help. However, Chevys are probably the easiest to swap things around in and I know there are some guys around here that have done this and can tell you what to look for.
Good luck! | | |
#14949 02/04/2003 4:16 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The truck you speak of also was available with a V-8 engine. The tranny and bell-housing will bolt up with no problem. You will need to locate V-8 mounts, exhaust, linkages and a few other small odds and ends.
