0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#1494459 03/29/2023 8:44 PM
8
nothing beats a try but a failure
8 Offline
I’m on to the soldered joints on the driver’s side. The A pillar to the roof and the A pillar to the cowl will need to be welded after removing the solder. I will fill the top joint with weld. But, after welding the bottom there still be large a depression. I’m not sure what to finish filling the joint with. What have you all done to fix this joint?
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
87GN #1494469 03/29/2023 10:02 PM
The joint was already welded at the factory (a lapped joint held with spot welds), so unless you're seeing it broken loose, you don't need to weld anything. If you want to remove the lead, do that and use body filler on the joint. I left the lead in place on mine and did what little touch up that was necessary with body filler. Be sure you have the lead clean before applying anything over it, including primer or filler.
87GN #1494506 03/30/2023 12:29 AM
I welded in a sheet metal patch in there to fill that deep depression and ground it smooth. Very little body filler was needed. I was not comfortable with using a big honking chunk of Bondo in that cavernous crater, given the small fortune to be paid to my painter.
That's another option. Lots of guys seem to think leaving the lead in place is bad, but it has lasted over 70 years so far. ohwell
8
8 Offline
Leaving the lead is my path. I am interested in filler with strands. The crater is deep.
