1 members (texczech), 51 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#1494396 03/29/2023 10:28 AM
I got a question about the type of drill bit to use on drilling out the steering arms. I am putting disc brakes on the 1950. I have to drill the spindle to 1/2. Not a problem, but the steering arms are eating drill bits like candy. Any help would be great. Thanks Tom
I had a similar problem and while I eventually got it done I have a lot of trashed drill bits to show for my effort. I will following along just to get smarter about what I should have done.
1949/50 3600 Project
Follow in Project Journals
H Online: Content
Use a carbide bit in a drill press, low spindle speed, and plenty of lubricant. You should be able to find a solid carbide bit on Ebay. A very short one would be best, as carbide is brittle, and breaks easily. Be sure to clamp the steering arm tightly to the drill press table- - - -don't try to hold it by hand.
For instance:
www.ebay.com/itm/275617376778?
