5 members (Steelonsteel, klhansen, Bill Hanlon, Hotrod Lincoln, 1 invisible), 148 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
Page 5 of 13 1 2 3 4 5 6 7 … 12 13
AD Addict & Tinkerer
Been following and it looks great. Nice work!
If you do decide to angle the tips up, drill a 1/4” hole at the lowest spot to allow rain\condensation to drain.
Phil
Project Journals
Stovebolt Gallery Forum
Thanks for that idea Phil...I'm still not %100 committed to the exit location. Going straight back might be the cleanest look but I'm not sold on that either. It's taking a lot longer to get this final piece figured out than I'd originally thought it would.
1940 1/2-ton
Low skill and low buck build
Follow in the Project Journals
In the dark of night, she's a looker.
Somewhat productive day, finalized the rear exhaust route… enough so that it’s tacked, dad got primer on the fenders and test fit the bed wood.
1940 1/2-ton
B Online: Content
That is going to be a long battery cable. Hope it is big enough.
I’ve got 1 gauge to run from the starter to the solenoid, then the kill switch and finally to the battery. Should all be good.
1940 1/2-ton
Ran my battery cable from the solenoid to the starter and put in the passenger side glass.
1940 1/2-ton
Fenders got paint today, version 2.0 of the floor got started and played around with another set of hub caps
1940 1/2-ton
Are those hub caps '60s "dog dish" style???
~ Dan
1951 Chevy 3 window 3100
They do have a slight dome but I suppose they are technically dog dish style. …I mean you could flip it over and let fido drink his fill out them.
https://www.summitracing.com/parts/WVI-1001-C
1940 1/2-ton
Yup, definitely appear to be the same as the "Police" version of "dog dish style". Was not aware they were being made to fit other styes/sizes of wheels.
Thanks for sharing!!!
~ Dan
Painting is done on the truck ..everything that needed paint got it... sort of...Turns out the rear passenger fender that had the wrong shape is going to be a complete redo. I figured I could fudge a little on each end and get it to fit.. big mistake. It needs the front reshaped to fit. Drivers side dropped right in so that's something at least.
1940 1/2-ton
Slightly frustrating day working on the passenger fender...clamped the fiberglass one to an original and you can see the distorted shape. Tried using a heat gun and a damp cloth to reshape the glass... that was mostly pointless. So, I cut the sucker in half and may attempt to re-glass it in the proper shape. For now I'm back to the ugly as sin original fender that needs a bunch of work to make it right. On the upside, tailgate still fits.
1940 1/2-ton
Crusty Old Sarge
Crusty Old Sarge
That black finish is outstanding! Did you decide to use the steel wheels and caps after all?
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Other than my fender issue the trucks turned out pretty decent.
I'll be swapping out between the solids and the D's depending on my mood. I picked up a second set of hub caps for the solids, so I can switch them up as well. Variety being the spice of life and all that... I like to have choices or I simply can't make a decision... either one works smile
1940 1/2-ton
Crusty Old Sarge
Crusty Old Sarge
My BIL occasionally removes the front bumper on his 56' 210, makes everyone think there is another car in town. grin I love watching your progress.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
First and possibly the only time that the tailgate gets used like a work bench
1940 1/2-ton
Some random updates… rear glass is in, fender surgery underway, rest of the headliners in, got the new km/hr speedo glass in and changed my 2 post kill switch for a 4 post
1940 1/2-ton
Today was interesting. My slip yoke arrived along with the cut to length driveshaft. Running 1350 ujoint at the trans and 1310/1350 at the rear pinion which is all good. Trouble arose with the th400… it’s from a truck and has a bolt on yoke which was a know item. What I didn’t realize is that there are 2 sizes of yoke and the one in the trans tail housing is a smaller diameter than the slip yoke.
In a brilliant stroke of luck… when we picked up the th400, the seller had a second th400 that he was throwing in at no extra cost. Also a truck trans but turns out the tail housing is the larger diameter… so after a bit of a hassle the slip yoke is in.
Dad saved the day… he was the one that wanted to take apart the junk trans and compare them.
1940 1/2-ton
Who says fortune doesn't strike in unexpected places these days - lol! grin
Glad to see you overcame another potential gremlin. Congrats to Dad for saving the day! yahoo
~ Dan
Welded up/clamped some of the exhaust today and hung the door panel… and one of the door panel pics is sort of wild with the reflection
1940 1/2-ton
Minor updates…Rear bumper is on, drivers side exhaust is almost done… I changed the layout again. Working on the battery and alternator cables. Fibreglass rear fender repair failed miserably so it’s on the back burner for now.
1940 1/2-ton
Driveshaft is done and in.. but like everything else it wasn't simple. I ordered a DIY from Summit and it showed up dented on the end, which wasn't a big deal since it would be shortened, however it was also bowed in the middle. Ended up having a local company build the driveshaft. Highly recommend Western driveline in Nanaimo if you're on the island and looking for driveshaft work.
1940 1/2-ton
I loved the original color combo on the truck. But I love black even more. The dark stained bed looks so nice.
^Thanks
Spent some time working on the floor... notched the toe board and started fitting the main section of floor
1940 1/2-ton
Got a 3 day break in the weather this month so it's an earlier thread resurrection than normal. Latest progress report: changed my mind and refit the D spokes, adjusted the rear brake shoes, rear turning indicators are in, rear fender mounted (for the umpteenth time), got the extended traction bars mounted, some more exhaust work done and the wiring temporarily started up again.
1940 1/2-ton
Got some work done on v2.0 of the floor.
1940 1/2-ton
Fox Offline
That looks sharp.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
The edges of that sheet metal are indeed sharp… So I wear gloves 😁
1940 1/2-ton
Couple more cuts in the floor, somehow still not finished. The radiator hoses are clamped and the throttle return springs are in.
1940 1/2-ton
Drilled a hole and put in a grommet to run the indicator wires through.
Played around with an old steamer trunk since the truck clearly lacks storage. Thoughts are to drill through the base of the trunk and use the bed bolts to hold it in place.
Not sure if the trunk is too large
1940 1/2-ton
Unconventional Thinker
Truck looks great! Trunk looks to be the right size.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
^ Thanks… the more I see the trunk in there the better i am with it.
1940 1/2-ton
Little more floor work. Moved the original battery access door to the drivers side as an access point to the master cylinder. Taking awhile since it’s a drill, jigsaw and some hand files… envious of those with “real” tools and the skills to use them.
1940 1/2-ton
Fox Offline
Man, you’re doing amazing! If you had the tools necessary, it would have been too easy for you. Looking great!
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
^ Thanks Fox
Floors getting closer to being finished, little finish work and it’s done. Modified an AD trucks parking brake boot to fit the 40… looks like it will work fairly well.
1940 1/2-ton
Picked up a battery and got some wiring done. Battery is a group 78, side post. Where I mounted the battery tray there’s no way a top mount would fit.
1940 1/2-ton
Getting the wiring worked out. Had to turn the solenoid upside down as I had the battery on the I post and the alternator on the S post. Marked them with paint so that shouldn’t happen again. Good news is the kill switch works and the starter spins right up. Kind of cool and terrifying at the same time to hear the truck attempt a come to life moment.
Now that the solenoid’s wired correctly, chasing down why the power wire to the fuse box doesn’t have power. Thought it might be a bad join in the wire when it was extended but dad remembers a wire being “soft” in one spot… of course that’s the power wire.
Drivers side exhaust is done… 1 down 1 to go
1940 1/2-ton
So… turns out that when you extend 2 wires with different colours, you shouldn’t rely on memory. Had the two wires crisscrossed in my head…redid the red power wire extension with red so no more confusion… at least that’s the theory. Truck has dash lights, high beam indicator, tach light and low/high beams.
At some point this is supposed to be fun… not there yet.
1940 1/2-ton
Crusty Old Sarge
Crusty Old Sarge
That's strange... looks like fun to me! thumbs_up
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
In some twisted sort of way… I suppose it could be… grin
Truck has taillights and got half the MSD box wired.
1940 1/2-ton
Moderated by  Phak1
