3 members (Danielbolt, bluechev, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 68 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 68 | Need some advice, my alternator was working fine charging at 14v or higher. I put a bracket on wrong and it started hitting the alternator fan. So, I fixed it immediately after I realized what I did. Then hooked the alternator back up, and now it will not charge. I put the multimeter on it and now it is reading 11v and no more. So, I took the alternator, and had it tested and two auto parts to see if that was the problem. Both auto parts came back that the alternator was fine. I also put on an old alternator I had laying around with the same result. I checked the fuses, and they have continuity on both sides. I recently put in a new wiring harness so there is no corrosion. What could the issue be?
Mike
| | | | | Joined: Oct 2021 Posts: 6,929 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,929 | If the alternator truly is fine, it has to be a problem with the wiring connected to the alternator. Does this alternator have an external voltage regulator? If so, check that.
1950 Chevrolet 3100 (Ol' Roy)
Mike
| | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | We probably need to know what kind of vehicle you're working on, and whether the electrical system is original to the vehicle or some type of conversion.
Last edited by Woogeroo; 03/24/2023 1:21 AM. Reason: edited by hall monitors, Jerry has frilly undies
| | | | | Joined: Jul 2000 Posts: 2,200 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,200 | Do you have a separate ground wire for the alternator or are you just relying on it being grounded through the mount to the engine?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2023 Posts: 37 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 37 | Do you have a separate ground wire for the alternator or are you just relying on it being grounded through the mount to the engine? Especially if the bracket has been powder coated or painted. Regardless of issue, and it might go without saying but I think I'd run the battery charger for a bit if only 11 volts. Otherwise I'm over here in the cheap seats watching to see the solution...........
1958 3100 Fleetside w/235 4spd
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Mike Bell With your alternator turning at fairly high rpm see if that bearing opposite the pully is magnetic,if it is alt is primed. Could run a wire to the battery thru an ammeter watch out making sparks near the battery,can blow. Be sure ground is connected. Fuses that have been blasted can get a coating on the inside that will show a circuit to your ohm meter.
| | | | | Joined: Jan 2020 Posts: 68 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 68 | Chevy 3100 1950, it has a updated 12v wiring harness.
Mike
| | | | | Joined: Jan 2020 Posts: 68 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 68 | I have several grounds on the engine, cab, and frame, but not one right on the alternator.
Mike
| | | | | Joined: Sep 2009 Posts: 5,980 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,980 | Mike,
Perhaps you can provide a couple of pictures of your alternator and bracket set up?
There may be something we could see that might lead to further help on the problem.
Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jan 2020 Posts: 68 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 68 | I figured it out, it was a ground issue. The bracket had been powder coated, I added a ground wire to the alternator and it began working again, thanks.
Mike
Thanks for coming back and sharing the solution you found.
Guess that means ascwranger1 gets the best helper award as he nailed the problem! Gord also earns one for having the base problem ID'd!
Enjoy the weekend all!
Dan
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Mike Bell Great !! I like to hear that special noise a Delcotron makes when it is happy to be working.I have a regulator testor I made so you can shuck em in and out easily. My neighbor tested a 5 gallon bucket of regulators so we're stocked !! | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Just for information,my alternator teacher would test the triode by seeing if all 3 circuits would light an ordinary 4 lamp system low beam headlamp,done a lot of them that way. | | |
